Sqaure Footage
johnkapanick
If you have Home Designer Pro you could draw a closed polyline around anything and then open the polyline's dialog and see how much it encloses in terms of square feet. Those titles that have the enclosed polyline tool should also work, if what you have does not then your only solution is to upgrade to Pro or Premier.
