Bath enclosure modification
DeePrice
Have a bathroom that is using a secondary base board as the "wainscot"; works well until you build a shower enclosure.  I could adjust the tub and add a partition to solve my design issue, but I would like to know that if I was to break the wall in two areas, on each side of the tub, would it eliminate the chair rail and allow me to carry the tile upward to the desired height.
See picture for clarification. Wall to right is soffit, not the partition in order to capture crown molding.
D.C. Price
Home Designer Suite 2018
