Chairs d isappear
Keith_K
Go to solution Solved by Keith_K,
In a council chamber on my plan I created two areas of public galleries by using the stairs tool i.e. making them wide, with wide treads and10mm risers - the latter to give those sitting behind the first row which is at floor level - a measure of elevation from which to view the goings on of the council.
I can place seating on the floor level, as you will see from the attachment, but when I try to place rows of seating on what is effectively the tread of the staircase it will be visible until such time as I click on something else and then it disappears.  If I click on the space where it used to be it appears again but then vanishes when I move away.  I have tried making adjustmentssing the object dialogue "height above floor" setting but it makes no difference.
My thoughts were that using the stair tool would be far easier and quicker than fiddling about with soffits but it seems as if said thoughts were totally wrong.
Is there some way that I can get the chairs to stay where I want them?
  • 2 weeks later...
