Roof Question
Monte96
Can anyone help me with creating an offset roof?  The back of the house is flat across, but the front steps up about 1 foot almost halfway across.  I can't seem to figure out how to manipulate the roof.
IF you are using Home Designer Essentials, Suite, Interiors or Architectural you must set the ceiling heights higher so that the roof generator then "knows" to create the roofs higher. (Higher ceiling heights equals higher roof planes)
If you have Home Designer Pro you can do the same as above plus just manually raise the roof planes you need to be higher by changing their baseline height figures in their dialog boxes.
What software do you have?
