Changing dimension number
crosscutter55
I believe you are correct in saying that dimension text can only be centered, above, or below the lines.  Being able to rotate the text 90 degrees to the dimension line is pretty basic in most cad programs.  HD pro seems to be limited to a number of things associated with dimensions.  Another example of it's limitation is the ability to draw walls using ID room dimensions only.  One has to use several methods to do this.
