Exterior pattern not filling under eave
Daddiosbullitt
Always post the .plan file. Layouts don't help.
If there is a wall there, it looks like an interior wall.
Read up on Lower Wall Type When Split by Butting Roof. This gives you the ability to have one wall type above the roof, and one below.
The exterior wall seen in your image stops at the intersection of a perpendicular exterior wall, the reveal that shows is the edge of an interior wall at that intersection (a common occurrence) you can cover the interior wall reveal with a thin soffit or perhaps a custom slab if you like. Repairing such an occurrence using walls is unnecessarily complex and not recommended.
