Window Casing around bank of windows
ChiefuserLarkin
Your windows don't have "Casing" for the exterior checked, but that's going to put casing around the whole window.
I don't think any of the Home Designer programs let you mull windows together to do what you want, and they don't have the manual moldings tools that Premier does, so a custom backsplash or even using the Closed box shape from the Library for going just around the outside of the windows to fake the look of trim is probably your best bet without upgrading.
Also, it looks like you may have used "Copy/Paste Hold Position" a few too many times.  The top and bottom windows on the left (when viewed from the outside) both have two windows at the same spot.
