stair railing types
mitzie
   I am trying to create modern stair rail such as cable or glass. I cant seem to do it with half walls and such.  If I select balusters in fencing it shows as perpendicular to the stairs. How do I create glass or cable railing? I'm using HDA 2014
Using a Half Wall, place it a 1" or so on the stair.   Open the specification box and make your changes, to get the glass, change it from solid to panel
and then click materials>panel, click select material and change to glass.  To get the cable rails you have to use a object from 3d warehouse and then edit the object in Sketchup.
