Incomplete Roof
stanyite
Go to solution Solved by DavidJPotter,
A small section of my roof is not building correctly.  As the image shows, there is a depressed area with multiple angles/planes that I cannot delete or correct.  I've tried aligning walls and double checked all my wall heights but I'm getting nowhere.  I am attempting to create a saltbox roof over the two-story part of this plan.  There are no objects or elements found in the attic.  Any suggestions would be greatly appreciated.post-7863-0-01141800-1470516179_thumb.jpgpost-7863-0-91270900-1470516473_thumb.jpgpost-7863-0-76853000-1470516609_thumb.jpgpost-7863-0-68239600-1470517314_thumb.jpg
Edited by stanyite
Thanks, David.  I slowly began moving the knee wall away from the ridge line (toward the covered patio) and after moving and checking in one inch increments, the roof generator removed the depression and now looks correct.post-7863-0-09179000-1470519901_thumb.jpg
