Add Gable Above Entry
russewb
The entry gable shown in the example image will probably need to be built using manual roof plane tools in HDPro since it will intersect a gull wing roof design (i.e., the porch roof having flatter slope than the main building roof).  It wasn't clear in the plans where you wanted the gable as there was no apparent opening to indicate the location.
When I manually draw the gable it makes the entire roof line come to crazy pitches with gaps in the center. I would just like the have it centered on the front of the plan. If I am supposed to manually draw it, based on the instructions online I should draw the gable line parallel to the outside wall I would like to have a gable placed on? In this instance since I have a porch, do I draw the line on the invisible railing?
LawB10 - I can't open that version for some reason...are you using 2017?
David - that was a good help on the other issues with the roof, but can you show me how to add the gable from that picture to the front porch? Just centered along the porch will be fine.
