Rail/fence bottom edge
Vikki_WA
Go to solution Solved by DavidJPotter,
In a 3D view I can select a wall and get edit handles on all sides so that I can change the top and bottom heights of the wall, but this doesn't seem to be available with railings (no top or bottom handles). The default top and bottom height are greyed out in the dialog box as well. I want to lower the bottom of a fence to drag it below the terrain ("bury" the bottom). Any idea how to do this?
