A strange hip ridge is added?
cte677
Probably more like "unwanted" as opposed to "Strange". You can vary the ceiling heights in various areas until you get a more acceptable result or you can upgrade to Home Designer Pro where you can manually edit and create roofs not dependant only upon settings as in Architectural, your choice.
