Foundation gone in 3D view
Fidellaty
Go to solution Solved by solver,
My best guess is that you made that image using the "Floor Camera" which excludes by default anything but just the floor on which its viewpoint is created (it is supposed to do that). Provided you built a foundation a roof and or upper floors they will appear only in a "Floor Camera View" (designed to include all that can be seen from a particular viewpoint). Or other camera types designed to include the entire model and its parts. I rarely ever use the "Floor Camera" for this reason. DJP
  • Upvote 2
Does this room specification dialog tell you anything?  Some of the items are grayed out.  The garage is lower (even walls and roof) than the rest of the house, as it was an addition.  I was trying to figure out how to do that before "this" happened.  I checked the camera view and that wasn't the problem.  I've tried rebuild foundation.  I've also attached a copy of the Foundation Defaults dialog.
Like this...  (see attached)
I was going to start over because I realized I could have done a few things differently to start with, but if this can be fixed that would be great.  The front porch/roof is going to challenge me too.  See the house (attached) I am trying to replicate.  Thanks.
Home.plan
After reading through the reference manual, I'm inclined to say that the problem I was having was not knowing the layer sets are file specific.  From page 76 "Layer Sets".  Changing a display option in Floor Plan view does not change it in Camera view.  I must have turned off the foundation display in Camera view and then thought it should have been turned on looking at the display options for Floor Plan view.
