Two Ceiling Heights
rcspott
Hi
Trying to design a warehouse with 12 ft ceilings. Inside the warehouse I am trying to have 2 rooms that have 8' walls and ceilings. One of the walls to each room share an exterior wall. Want to be able to store things on top of those 2 walls. Not able to achieve this. Plan attached.
HD Pro 2015
Hope this is clear.
Thanks
Untitled 2.plan
This is a fairly common request/problem. The software design makes this more complicated than it should be.
You can model this by adding a 2nd floor. Think of everything up to the 8' level as floor 1, and everything above as floor 2.
Use a room divider to outline the rooms below, and make the rest of the 2nd floor open below.
