Privacy Fence
ChadEdwards
Go to solution Solved by ChadEdwards,
How do I use the Fence to create a standard 3 rail, 5-1/2 in dog-eared picket fence?  I tried the panels from library but they come in weird width and rotated towards the view, not in-plane with the fence line.  I tried 5-1/2 in ballusters but it makes them square and too thick. I searched the KB but not much on it.
Chad
HDP-2016
Thanks, yes I saw that post already, but when you actually try to create a fence like I describe it is not working... how do you use the dog-eared panel to create one, does not work for me.  I also don't see Gates in the catalog under that location or anywhere else??
Just follow the article.  :)
Draw a fence. Open it and change the panel type to the one from the library. Change the height. Change to Post to Rail, or one of the other settings to make it look correct.
Gates are in the library, but none match the fence.
