A stair problem
Halcyon
Go to solution Solved by Halcyon,
Walls don't align because the main layers do not align. Walls were drawn in opposite directions, so they are reversed from one another.
Fixing the wall poly line gets the door back, but there is a gap in the floor.
See the image where I painted the lower floor walls green.
  • Solution
Thank you David & Eric.
I know where to look now so will spend some time sorting it out. Strange thing is that I have been fooling around with that staircase for a long time and this problem has only come along lately.
I'll put it down to gremlins.
Thanks.
Pat
