extending a gable roof
dave6115
Select the railing that is parallel to the house, and make that a gable wall. Voila, gable porch! I just did this on a plan I'm working on right now.
|    house                             |
                |  porch |
                +---------+   <-- make this a gable wall even though it is a railing.
I did this in HDA 2015. Good luck!
Susan
As Sue pointed out if its a Porch the Roof will build auto if your move the railing out , Decks don't have Roofs by default, so you will need to turn Roofs back on in the Deck Room's DBX (dialog Box) on the Structure tab for it to show up after moving the Railing
