Updating from Pro10 to Pro16
bigalinda
I am considering updating or buying the new Pro 16 software. If I buy new, will I have to deactivate my license on Pro 10 in order to use Pro16 ? I am still using Pro 10 and may have to refer back to it if i do more work on a particular design in the future. Can the designs be imported from Pro 10 into Pro 16?If I download a trial version of Pro 16 will it impact my Pro 10 version? Also if I chose to upgrade I am afraid it may not work properly as my wall tool on Pro 10 is not drawing straight. I have to use the make parallel/ perpendicular to straighten it each time. Thanks
I upgraded from Pro 2015 to Pro 2016. 2015 still works. Newer versions can open plans created in older versions, but not the other way.
You don't really upgrade the software, you get a complete new version at an upgrade price, so Pro 10 will not be affected.
As for drawing walls straight, check your Angle Snaps setting.
