Base Cabinets @ Less/Greater than 90 Degree Corners
cxcarter
I am runnng HD PRO 2016:
Is there any way to design the triangled areas where base cabinets meet on angled walls where the walls are less than or greater than 90 degrees?  If the walls are 90 degrees then a corner cabinet can be built; however, any other angle does not appear to conform to the angled walls.
I would like to create corner doors where two cabinets meet and gain access to the voided area(s).
Thanks for any help that can be rendered.
cxcarter
  • 8 years later...
I want to do this too. Attached is a snipped image with the area shown on plan in a dotted red circle where I want to create a cabinet that wraps around this corner angle. Any help would be much appreciated. (Couldn't attached the file as it is too big.) I'm also working with 2016 HOme Designer Pro.
Thank you.
