How to select items on multiple floors
chexone
Go to solution Solved by DavidJPotter,
Hello, does anybody know how to select items on multiple floors.
I want to copy/paste an entire structure (foundation, first floor, attic/roof) to a different plan without having to do each floor separately. It's proving difficult to reconstruct the structure when doing it piecemeal.
Thanks!
IF your software has the command " Edit - Edit Area - All Floors" then you can use that to copy-paste your drawing to another plan. What software do you have (its name and version number)?
That did it, thank you!
I have Home Designer 2015 Pro, so I did indeed have that option. Quite useful.
Why not just do a File> Save As and create an exact copy of the file by giving it a new name?
Well, I had 2 plans. One has a multi-level deck, and the other has the house. So I wanted to copy the house into the deck plan.
