Frameless Cabinet Configurations
DIYPlanner
Go to solution Solved by DIYPlanner,
I'm using Home Designer Pro 2015.  Our plan will include kitchen cabinets are not boxed (older house) . Cabinets have a drawer below the counter, and doors underneath the drawer.  Depth of the drawer section is 23".  Cabinet depth below the drawer is only 20".  So far, I've managed a work around to build the cabinet drawer and door sections as SEPARATE CABINETS, then adjusted the height from floor so the drawer is positioned above the door as measured.  Is this the only way to go or have I missed a feature that I could be utilizing? Thanks for everyone's input.
can you post some pics perhaps ( see my Sig. for a how too if needed)  cos your description sounds like the typical base cabinet to me ,except for what I think is the notched back (3"), Though as far as the software goes I am unsure why you would need to model that notch ?
you might want to add your Title and Year to your Forum Profile Signature so you don't need to add it every Post too, like Eric and I have done....
