Fill color in door opening
Geoff-Nanaimo
Go to solution Solved by Kbird1,
  • Solution
1st time I have seen this question , the "white" is your background colour ( in preferences) , not sure how you "coloured your Rooms"  though? as I'm not familiar with Essentials so not sure what options you have, I assume you want the purple and green in the doorways?
You could possibly make a thin Soffit (cabinet menu) (width of wall X width of Door X 3//4" thick set at 0" above floor) and colour it to match each room and place it in the doorway to hide the background ..... same idea for the shower stall if needed
